1992 Honda Accord Radiator and condenser
PRODRIGUES
1992 Honda Accord 4 cyl Front Wheel Drive Manual
My radiator is leaking like jet when the car is hot but the problem seems to be with the condenser because I see the coolant coming out of it.
My questions are: The condenser needs coolant? Is the condenser just a way out for the leak from the radiator? If does it explains why it leaks. Do I need to have the condenser?
Thanks
Oct 15, 2009 at 2:25 PM
BMRFIXIT
  • 19,053 POSTS
Condenser have refrigerant gas and oil only no coolant or water or antifreeze
and no reason for it to be leaking any antifreeze
my thinking is that the radiator is leaking so bad that making it look like its coming from the condenser too
remove the radiator and replace
Oct 15, 2009 at 3:18 PM
