1992 Honda Accord power steering pump
ESTIY
  • 7 POSTS
Steering problem
1992 Honda Accord 4 cyl Two Wheel Drive Automatic
since my garage replaced a leaky pipe from the steering pump to the box I have a grating noise when turning the steering wheel.they tell me its air in the system but don't seem eage to cure this.how can I bleed the air out
Aug 7, 2008 at 6:36 AM
KHLOW2008
  • 41,812 POSTS
Hi estiy,
The system is self bleeding, you just need to make full left to right a few times and it should be ok.
I suspect the noise is from the replaced high pressure pipe, it will produce groaning noise if not replaced with OEM parts.
Aug 9, 2008 at 4:00 AM
ESTIY
  • 7 POSTS
Thanks KHLow2008.I thought the pipe had a different design than the original Honda part,now I know why they don't wish to do anything about it. Your help is fantastic,groan is the exact sound,really appreciated.
Aug 10, 2008 at 4:27 AM
