1992 Honda Accord Most Likely
209,000 MILES • 4 CYL • FWD • MANUAL
FINGERNUT
Negative camber on my '92 Accord EX on the front wheels. Which is most likely - Upper balljoints, lower, struts, or all of the the above. Where do I start first?
May 15, 2008 at 11:43 PM
MASTERTECHTIM
  • 4,750 POSTS
have you had it aligned? if the front end parts are not worn out you can correct it by a alignment
May 15, 2008 at 11:52 PM
