Hi chevyman6568,
Remove the air intake hose.
Drain the coolant.
Disconnect the lower radiator hose.
Disconnect the heater hose from pipe near water pump.
Remove the thermostat housing assy, removal of 3 bolts and a ground connection.
Remove the 12 mm hex bolt holding the pipe bracket next to oil filter.
Pull pipe out of connection at water pump and wiggle it out.
SPONSORED LINKS
Tuesday, December 22nd, 2009 AT 10:45 AM
