1992 Honda Accord Jerking on Acceleration
156,000 MILES • 4 CYL • FWD • AUTOMATIC
KREEVES10
  • 10 POSTS
I have a 92 Accord that drives great. It is a automatic however when i am accelerating i can tell there is a jerk when it is moving between 1st and 2nd gear and maybe even between 2nd and 3rd. Again it isan automatic but you can tell when a car is moving between gears. What could be the casue of this problem. Mechanically this seems to be the ONLY problem this Homda has once i get up to about 35 40 it is smooth sailing.
Jun 8, 2010 at 8:31 AM
  • 75,988 POSTS
Tranny could be slipping if not do below
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 8, 2010 at 9:46 AM
KREEVES10
  • 10 POSTS
Thank you. I hope its not the transmission. I will begin with all of the other suggestions first.
Jun 9, 2010 at 12:23 AM
