1992 Honda Accord Heater Blows Hot Air then later Hot air t
135,000 MILES • 4 CYL • FWD • AUTOMATIC
PIMIX2009
My 92 Honda Accord has a heat problem. It blows hot air only if the fan speed is on 1 or 2 but if the fan is on Max. it will blow cold air. I change the thermostat and flush the radiator coolant and added coolant but still some result.
Jan 11, 2010 at 6:11 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect not enough coolant circulating through the heater core
and heater core need to be isolated and flushed
check heater valve if fully open too (under hood by firewall )
Jan 11, 2010 at 10:31 PM
