1992 Honda Accord electric window and power to radio area a
KJDEWEES7
Electrical problem
1992 Honda Accord Engine Size unknown Front Wheel Drive Automatic 214000 miles
We have lost power to the radio and power port. I changed the fuse but it didn't appear to be out anyway.
Driver power window will go down but not up.
Door lock has stopped working on all but one door and it only works to lock, not to unlock.
Can you adivse?
Jan 5, 2008 at 5:14 AM
2CARPRO JACK
  • 11,533 POSTS
there are 2 radio fuses, one in the underhood fuse box and 1 in the interior, be sure both are good.You will need a test light to figure the rest out. Which door does the lock work on? was this a sudden thing or gradual loss of different locks? Driver window might be the switch or motor, will need to remove the door panel to gain access to the motor, once again you will need a test light to see if the power switches back and forth at the motor when you select up or down
Jan 5, 2008 at 11:55 PM
