1992 Honda Accord Dashboard Lights
105,000 MILES • 6 CYL • FWD • AUTOMATIC
LOLSTER
My Honda's Stop/brake light came on along with the brake lamp and then ABS and now the Sport light is stuck on after I accidently knocked it.
All within a short space of time.
Jun 5, 2008 at 7:54 AM
KHLOW2008
  • 41,812 POSTS
Hi Lolster,
At the gear shift there is a switch, press and see if the S light goes away. If not you have a broken switch and need to replace the gear shift.
As for the brake failure indicator. check for blown brake bulbs.
The ABS light would come on if the brake master cylinder fluid level is low or the handbrake is not fully released. Check the fluid level first.
Jun 6, 2008 at 12:18 AM
