Hello.
I have attached info on the two codes. Code 2 is for the lock up control solenoid B. I have attached information on check out of both A and B and how to change.
Test For Lock Up Control Solenoid A & B
NOTE: Lock-up control solenoid valves A and B must be removed/replaced as an assembly.
Disconnect the connector from the lock-up control solenoid valve A/B.
Measure the resistance between the No.1 terminal (solenoid valve A) of the lock-up control solenoid valve connector and body ground, and between the No. 2 terminal (solenoid valve B) and body ground.
Replace the lock-up control solenoid valve assembly if the resistance is out of specification.
If the resistance is within the standard, connect the No. 1 terminal of the lock-up control solenoid valve connector to the battery positive terminal. A clicking sound should be heard. Connect the No. 2 terminal to the battery positive terminal. A clicking sound should be heard. Replace the lock-up control solenoid valve assembly if no clicking sound is heard.
Service and Repair
Notes
Remove the mounting bolts and lock-up control solenoid valve assembly.
NOTE: Be sure to remove or replace the lock-up control solenoid valves A and B as an assembly.
Check the lock-up control solenoid valve oil passages for dust or dirt and replace as an assembly, if necessary.
Clean the mounting surface and oil passages of the lock-up control solenoid valve assembly and install a new filter/gasket.
Check the connector for rust, dirt or oil and reconnect it securely.
Code 15 is the main shaft speed sensor. I have attached info on how to check that also.
Remove the 6 mm bolt from the transmission housing, then remove the mainshaft or countershaft speed sensor.
Replace the O-ring with a new one before reinstalling the mainshaft or countershaft speed sensor.
Sep 27, 2018 at 1:39 AM
(Merged)
