Noticed that my car was low on coolant so topped off. Then 2 days checked again and low again. Checked for leaks in system but none could be found. Ran car and looked around system and noticed that when ran for a while, coolant would fill into the reservoir and over flow which would be the reason of the low fluid. Not sure what is causing this, water pump (replaced with timing last year, thermostat (replaced few months ago)? When ran w/o cap water did not seem to circulate just slowly flow out of radiator. hmmmm
Jul 27, 2009 at 12:24 PM
