1992 Honda Accord Brake pedal goes to floor board when AC i
192,000 MILES • 4 CYL • FWD • MANUAL
TODDS92ACCORD
When we use the AC the brake pedal goes to the floor board ever so slowly. When the AC is off the brake pedal works just fine and the brakes work fine. I even try to pump the pedal when the AC is on and it slowly goes to the floor board but the brakes do activate and stop the car. What could be causing the problem? Is it the brake cylinder? Why is it only when the AC is activated?
thanks for the Help,
sincerely,
Todd
Jul 12, 2010 at 7:28 PM
KHLOW2008
  • 41,812 POSTS
Hi todds92accord,
Symptoms indicates the master cylinder is faulty and has to be repaired/replaced.
I have no explanatin as to why it fails only when the A/C is turned on.
Jul 15, 2010 at 7:00 AM
