Hi emchjane,
The brake lamp failure indicator would come on if
1. one or more of the brake lamps are not working
2. Brake bulbs used are not of correct specs
3. Brake bulb failure sensor faulty.
Door ajar indicator shows when any door switch is not fully closed and it could be due to a shorting of door switch wires or faulty door switch, improperly adjusted doors.
Oct 17, 2008 at 8:06 AM
