MY PROBLEM IS WHEN I SHIFT THE CAR FROM PARK, NONE OF THE GEARS ARE WORKING, THE BRAKE LIGHTS WORK, THE SHIFTER MOVES BACK AND FORTH
Apr 12, 2010 at 9:09 AM
KHLOW2008
✓Experienced Mechanic
Hi HLANE6104,
Is the shift lever very loose?
Prior to this, was there any problem with the transmission shifting?
Did you check the transmission fluid level?
Are any indicator lights showing?
