1992 Honda Accord
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
FRED VANCE
dome light will not come on when doors are opened.
all pins/plunger switches seemed to be frozen in door frame.
thank you
Oct 28, 2009 at 2:20 AM
KHLOW2008
  • 41,812 POSTS
Hi Fred Vance,
The plunger switches tends to rust and provide poor contact resulting in no operations when doors are opened. Remove the door switch and ground the sire to see if the dome light comes on. If yes, diassemble the switch and use sand paper to clean the contacts and they should be good again.
Oct 31, 2009 at 3:38 AM
