I have recently replaced a head gasket. The car was running fine when I started to work on it. I was careful to keep the timing correct but it would not start when I got it put back together. The number one piston is at top dead center, the rotary points at the number one spark wire and the notches on the fly wheel are lined up. The coil is working and the spark plugs are getting fire. Both valves are closed on the TDC position. I did remove the head without removing the intake manifold. There are two lines running to the gas bar- one has gas (Metal) the other (rubber) has nothing. Thr rubber one does nothing when I crank the car-(no vacumn or gas.)
The car does not even try to start when I crank it.
Could it possibly be out of time? What else could be the problem?
Jan 18, 2009 at 12:22 AM
