1992 Honda Accord
179,000 MILES • 4 CYL • 2WD • AUTOMATIC
EMBICK123
I have a coolant leak it spraying with high pressure when the engine gets hot right below where the top radiator hose connects to the engine. i also do not get any heat in the car? diagnosis?
Apr 23, 2009 at 11:04 PM
KHLOW2008
  • 41,812 POSTS
Hi embick123,
You should get a pressure test done to verify source of the leak. Most probaly the heater hose has a pin hole causing the leak. With sufficient coolant, it would not overheat. Once the leak worsens, the engine is going to overheat.
May 3, 2009 at 3:25 AM
