1992 Honda Accord
BRANDI_BELL
  • 1992 HONDA ACCORD
  • 4 CYL
  • 135,000 MILES
What would cause the right rear tire to wear on the outside edge? This was a brand new tire, driven only 4 months the tire is almost bald on the outside edge.
Friday, October 17th, 2008 AT 11:16 AM
KHLOW2008
  • 41,814 POSTS
Hi brandi_bell,
The rear wheel alignment is out and you need to check for
1. Improper Toe adjustment
2. Camber and castor readings. Check for worn bushes, control arm bushes and bent axles. Did you hit anything prior to this happening?
3. Check for bad axle hub.
Wednesday, October 22nd, 2008 AT 2:25 PM
