1992 Honda Accord
CALVINASP
Engine Mechanical problem
1992 Honda Accord 4 cyl 2.2 Front Wheel Drive Manual
in my 92 honda accord i can start my car if i move the Distributor forward just passed where you bolt it to the engine and then when its started i move it back to where it should be and it runs find. but i have to do this everytime to start it. the timing is good and the Distributor is new
Dec 1, 2008 at 9:42 AM
MASTERTECHTIM
  • 4,750 POSTS
i just had a honda give me same kind of problem. it felt as if the timing was too far advanced and it would buck when trying to start, i found that the starter motor was bad causing not enough cranking power. it was a last ditch effort and it was the first time i had seen a starter act this way but thats what fixed it.
Dec 1, 2008 at 11:17 AM
CALVINASP
ya the starter is new as well. i'm going to try and replace the computers under the carpet on the passengers side as well
Dec 1, 2008 at 1:18 PM
MASTERTECHTIM
  • 4,750 POSTS
look real close at the connector at the computer because i have also seen them corrode fromwater intrusion and sometimes unplugging them and plugging them back in work temporarily
Dec 1, 2008 at 10:59 PM
CALVINASP
i beginning to think its a fuel problem now or a sensor of some kind
Dec 3, 2008 at 7:23 AM
