I have done the timing belt, water pump etc.
Also put in a new distributor, plugs, wires the hole 9 yards. I was having a vibration issue for a fhile and so re-looked at the belts etc. Making sure all factory marks were lind up this time as the bottom was out so I turned it clock wise I think 2 notches- vibration seems to be gone but now I have an issue with the timing. I put the light on it and the mark is so far out you cannot see it unless you am the light up into the opening and no matter how much I turn the distributor it will not come into sight. Befor I fixed the vibration the timing was good but there was the vibration and fuel econoy was really bad only 280-300 tops to a tank. My last hond 92 would get well over 400km per tank.
I am now running out of time an as it is winter not the grates time to spend in the garage. Please help
Wednesday, February 4th, 2009 AT 10:15 PM
