1991 Honda Accord THIS CRAZY CAR
235,354 MILES • 4 CYL • FWD • AUTOMATIC
D-STINSON
HELLO...OK WHAT MY PROBLEM IS WHEN I CRANK MY CAR ONE TIME U CANT CRANK IT AGAIN FOR ANOTHER 6 OR 7 HOURS AND THE FIRST TIME WHEN I DO CRANK IT I HAVE TO HOLD THE KEY FOR BOUT 30SEC N THE GAS TO THE FLOOR FOR IT TO CRANK THEN ALL WHITE SMOKE COMES OUT AND THE CAR RUNS FINE SO PLEASE PLEASE HELP CAUSE IM LOSE N MONEY WIT EVERY ONE AND TOCO BELL DONT PAY ENOUGH
Aug 30, 2010 at 4:17 PM
KHLOW2008
  • 41,812 POSTS
Hi D-Stinson,
Thank you for the donation.
I am sorry I do not understand your question very well.
Do you mean you are not able to crank the engine for the next 6 or 7 hours if it does not start up the first time?
When you say cannot crank, do you mean the starter is not turning or it is cranking but not firing up?
Is there any abnormal indicator lights indicating?
Do you have coolant losses issues?
Have you tested the sparks? They should be bright blue while cranking.
Aug 30, 2010 at 10:45 PM
D-STINSON
you are very welecome for the donation...
yes, if the car does not start up the first time it will be 6-7 hours before it will crank again
what i mean about cannot crank is it will be turning over the spark plugs are firing but it just keep dumping gas but wantt start
the check engine comes n goes and this green light with an S in it for the sports tranmission always stays on
one more thing it did run HOT a few times but not any more
Sep 1, 2010 at 2:13 PM
KHLOW2008
  • 41,812 POSTS
Symptoms indicates a fault with the PGM-Fi main relay. The relay is knowm to intermittently fail due to cracked solders on its circuit board. Resoldering the circuit board would solve the problem.
https://images.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay90Accord_11.jpg
Sep 2, 2010 at 1:42 AM
