1991 Honda Accord surge
JOE.GONZALEZ79
  • 1991 HONDA ACCORD
  • 4 CYL
  • 272,000 MILES
When the car is in park it surges, once you put in gear it doesn't surge. The surge is irritating.
Sunday, June 29th, 2008 AT 9:52 PM
Check the electronic air control valve and throttle angle sensor-
Sunday, June 29th, 2008 AT 9:58 PM
ITSALLGOOD
  • 37 POSTS
The idle air control valve would cause that problem, but try replacing the PCV valve and the hose that's attached to it first. If the PCV valve is stuck open, or the hose is brittle and broken, it would cause a vacuum leak that makes the engine surge like that.
Monday, June 30th, 2008 AT 2:21 PM
