Follow the axles shafts and where they go into the transmission. Right above on the transmission you will see a connector and the speed sensor which runs off a gear that is mounted to the differential in the transmission. You only have to unbolt the top portion of the sensor as the lower half if only the gear that meshes with the gear on the diferrential.
Hope that helps if you have any questions please don;t hesitate to ask.
SPONSORED LINKS
Friday, March 6th, 2009 AT 5:22 PM
