1991 Honda Accord SMELL GAS
1991 HONDA ACCORD
185,000 MILES • 4 CYL • FWD • AUTOMATIC
GERALD HAMPTON
In the morning I smell gas in the car while warming up but after it warms completly it goes away, but only after driving on the highway for a while. What could my problem be?
Dec 17, 2007 at 4:32 PM
Sounds like its dumping fuel on it-might want to check for excessive fuel pressure with a gauge, coolant temperature sensor could be stuck in the open loop mode, or the oxygen sensor is not switching to adjust fuel demand, stuck open injector/s.
Dec 17, 2007 at 5:11 PM
EGONZAL24
You might have a leak on the injectors. When the car is cold, the smell of gas is stronger than when the engine is running (warm) Test by having somebody else turning the ignition key turn to the point you will see the engine light on the dahboard (do not crank or start the engine).
And you, as the second person with the hood open, look closely around the injectors if there is a gas leak. If there is, replace the rubber seals of all injectors. Even if there is just one leaking. Do it your self if you feel confident on doing the work or bring it to a mechanic.
Good luck.
Dec 23, 2007 at 9:37 AM
