1991 Honda Accord Shimmying
204,000 MILES • 4 CYL • 2WD • AUTOMATIC
DASEY716
I have a 91 LX When I am at a complete stop like when you are at a red light and you apply your brakes my car will go to about 400 rpms and shake really bad i cant even have my heater running or it will shake even worse same for AC once i accelerate it is fine could this be a battery or engine problem wasnt sure thanks
Jun 29, 2009 at 7:53 AM
F4I_GUY
  • 3,302 POSTS
Sounds like the idle speed is set to low to begin with. Try doing a throttle body service and make sure you clean the FITV and IACV ports (you'll see two holes/ports before the throttle plate)
Jun 29, 2009 at 9:37 AM
