1991 Honda Accord rotors
ADECENTANIMAL
Brakes problem
1991 Honda Accord 4 cyl Two Wheel Drive Manual
i am trying to change the rotors on my car, i have removed the caliper and the caliper bracket, as well as the axel nut, as well as the four bolts on the back of the steering knuckle. for some reason the hub assembly will not come off, i have tried everything, HELP!!!
Aug 31, 2008 at 10:15 AM
KHLOW2008
  • 41,812 POSTS
Hi adecentanimal,
The rotor is attached to the hub with 4 pcs of bolts.
You need to remove the bearing assy after loosening the rear 4 pcs of bolts holding the bearing and then tapping the bolts to get the bearing assy with the hub out. It might be stuck quite hard so requires some knocking but do not use excessive force which might damage the bolts.
Sep 1, 2008 at 3:13 AM
