1991 Honda Accord Right front hub bearing making grinding n
300,000 MILES • 4 CYL • FWD • AUTOMATIC
ARROYOKIMBERLEY
my right front wheel makes a grinding noise when turning and you can also hear it when driving. Could this be caused by the front engine dogbone mount?
Aug 23, 2010 at 3:49 PM
KHLOW2008
  • 41,812 POSTS
Hi arroyokimberley,
No, the front mount would not cause any grinding noise. Most likely the wheel bearings are bad. If the noise is a crocking type, then it is the CV joint that is bad.
If any repairs had been carried out near the wheels, check to ensure the backing plate is not brushing against thr rotor.
Aug 24, 2010 at 5:50 AM
