1991 Honda Accord oil in sparkplug cylender
219,900 MILES • 4 CYL • FWD • AUTOMATIC
EDDIE MORROW
i have oil in my spark plug cylender car will not start i think it may be headgasket proublems please help me know what to fix thank you
Jun 18, 2009 at 3:13 AM
KHLOW2008
  • 41,812 POSTS
Hi eddie morrow,
Oil in spark plug tube are caused by bad plug seals under the valve cover and not a bad head gasket.
Engine not starting could be due to ignition, fuel or mechanical. You need to test and confirm what is missing causing the non starting. Follow the link and click the link that aptly describes you present situation and go through the testing procedures to find out what is missing.
https://www.2carpros.com/kpages/first_things.htm
Jun 23, 2009 at 4:59 AM
