1991 Honda Accord o2 SENSOR failure
85,800 MILES • 4 CYL • FWD • AUTOMATIC
DNIEZGODA
Hi, can you help?
My honda ( uk spec model ith 4ws ) is showing the fault code for the o2 sensor, can you tell me is the o2 sensor fused and if it is, Where do i find the fuse?
The sensor itself is mounted in the exhaust before the cat.
Aug 15, 2008 at 4:35 AM
KHLOW2008
  • 41,812 POSTS
Hi dniezgoda,
There is no fuse for the O2 sensor.
The heated circuit gets its power from the ignition switch.
You need to replace the sensor if it is faulty.
Aug 16, 2008 at 1:51 AM
