1991 Honda Accord Idle Surge/TCC lock-up
USPSTECH
  • 1991 HONDA ACCORD
Engine problem
1991 Honda Accord 4 cyl Front Wheel Drive Automatic 275K miles
My 91 Honda Accord idle hunts when hot and in park. It surges constantly between 900 and 1700 RPM. This idle hunting is not affected by A/C compressor engagement. I also have a tcc issue and am unsure if it is related to the ide problem. My TCC lock-up engages and disengages rapidly at a rate of approx 1-2 seconds. (Ie: @70 mph---2700rpm to 3100rpm.) On-Off-On-Off-On-Off. This seems to happen less frenquently after 30 min of driving.
Thursday, January 3rd, 2008 AT 7:48 PM
BMRFIXIT
  • 19,053 POSTS
For idle
check coolant level and adjust
if needed
check for vacuum leaks
check idle air and clean
you may have to replace the solenoid
but check tranny ground 1st
good luck
Thursday, January 3rd, 2008 AT 8:28 PM
