1991 Honda Accord fuel starvation?
298 MILES • 4 CYL • FWD • AUTOMATIC
BONDSAN007
Alternator puts out 14V-battery 12.5V-good spark-idle hunts-will rev to about 4,000 rpm then starts to die unless you feather the throttle
Sep 30, 2010 at 8:24 PM
  • 75,988 POSTS
Check and test the fuel pressure if okay-Inspect and test the electronic air control valve, MAP sensor and the throttle angle sensor-
Sep 30, 2010 at 9:10 PM
BONDSAN007
Hey thank you for your reply-am still waiting for previous owner to let me know if he replaced the fuel pump and/or fuel filter-there is a new filter and "sock"(the strainer like thing at the bottom of the pump)sitting in the trunk.I will try your suggestions!Greg
Sep 30, 2010 at 9:27 PM
