1991 Honda Accord fuel starvation?
BONDSAN007
  • 1991 HONDA ACCORD
  • 4 CYL
  • FWD
  • 298 MILES
Alternator puts out 14V-battery 12.5V-good spark-idle hunts-will rev to about 4,000 rpm then starts to die unless you feather the throttle
Friday, October 1st, 2010 AT 3:24 AM
Check and test the fuel pressure if okay-Inspect and test the electronic air control valve, MAP sensor and the throttle angle sensor-
Friday, October 1st, 2010 AT 4:10 AM
BONDSAN007
Hey thank you for your reply-am still waiting for previous owner to let me know if he replaced the fuel pump and/or fuel filter-there is a new filter and "sock"(the strainer like thing at the bottom of the pump)sitting in the trunk.I will try your suggestions!Greg
Friday, October 1st, 2010 AT 4:27 AM
