1991 Honda Accord Fuel guage shows empty when full..
TEDDY WYLY
  • 6 POSTS
Electrical problem
1991 Honda Accord 4 cyl 66000 miles
Car has been sitting for 10yrs and I filled up the gas tank and the guage shows empty.. Could it be a fuse?
Mar 3, 2009 at 9:40 AM
F4I_GUY
  • 3,302 POSTS
Check to see if the sending unit circuit is fine. Yes you can check the fuses, that would be a quick and easy check. However you may have a faulty sending unit.
Mar 3, 2009 at 9:48 AM
TEDDY WYLY
  • 6 POSTS
If the problem is a fuse what fuse is for fuel guage and is it shared with clock or radio? To get to the sending unit what do I need to do? Thanks Ted
Mar 3, 2009 at 10:34 AM
F4I_GUY
  • 3,302 POSTS
The sending unit is inside the tank. On your vehicle I'm pretty sure if you remove the rear seat bench you can access the fuel pump and sending unit.
I am ensure about where the fuse would be located, check your owners manual.
Mar 4, 2009 at 9:20 AM
TEDDY WYLY
  • 6 POSTS
How do you get the rear seat out to get to the gas sending unit on a lx four door.. I've tried pulling the seat out put do not know what's holding it down..
Mar 7, 2009 at 6:29 AM
F4I_GUY
  • 3,302 POSTS
On some models it is necessary to remove the back supports to access the bolts holding it in near the back of the bench. Once the bolts are removed you push the bench towards the back of the vehicle to unlatch the clips and pull it straight up.
Mar 8, 2009 at 9:25 AM
