1991 Honda Accord Crankshaft Pulley is wobbling
183,000 MILES • 4 CYL • 2WD • AUTOMATIC
PILIPINO101
I was driving and there was knocking on on the engine at the driver side of the engine. I checked it out and the Crankshaft pulley was wobbling and the power steering belt and alternatating belt were hitting each other . I pulled it in my garage and reved it up; the power steering belt suddenly went out of line. How can I fix this? should i buy a new pulley bolt and crankshaft pulley? How can i loosen the crankshaft?
Jan 12, 2008 at 11:17 AM
FISHERMAN
  • 937 POSTS
[quote:0e1b6293fe="pilipino101"]Engine problem
1991 Honda Accord 4 cyl Two Wheel Drive Automatic 183000 miles
I was driving and there was knocking on on the engine at the driver side of the engine. I checked it out and the Crankshaft pulley was wobbling and the power steering belt and alternatating belt were hitting each other . I pulled it in my garage and reved it up; the power steering belt suddenly went out of line. How can I fix this? should i buy a new pulley bolt and crankshaft pulley? How can i loosen the crankshaft?[/quote:0e1b6293fe]
Hello !!
Once the harmonic balancer is wobbling there`s no sure fix, should be replace ..
the inner rubber absorbs the vibration and balance the crankshaft at the same time...
use a big braker bar and a socket and rest it against the floor then remove the ignition coil wire to prevent the engine to start and crank the engine for a second until the screw brake loose then probably you`re going to need an a harmonic balancer puller... (if its to tight) if not some wd-40 and get it out!!
Good Luck!!
Jan 12, 2008 at 12:48 PM
