1991 Honda Accord cranking
250,000 MILES • 4 CYL • 4WD • AUTOMATIC
LOVE1982
I was driving and my car shut off. So I put it in gear and it started back up. When I put it back in gear after starting it up it shut off again and it wouldn't this time start back up. The fuel pump does work cause i had that checked, but when we try to start it up it just keep turning and turning and turning and won't catch.
Nov 19, 2009 at 12:25 AM
  • 75,988 POSTS
Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Nov 19, 2009 at 12:59 AM
LOVE1982
My mechanic did disconnect the spark plugs, did everything you said to do and it is getting fire and gas but it still won't crank.
Nov 23, 2009 at 3:48 AM
  • 75,988 POSTS
Tell your mechanic to check engine compression and to verify the valve and ignition timing this is all you got left to check
Nov 23, 2009 at 3:51 AM
