1991 Honda Accord Condenser fan
75,000 MILES • 4 CYL • FWD • AUTOMATIC
1922ID
Hi, I have a 1991 Honda Accord, the problem is after driving the car and turning off the engine, the condensor fan runs for about 5 mins then shuts-off..........please help.
Apr 30, 2008 at 2:40 AM
BRUCE HUNT
  • 3,754 POSTS
That is normal, but can be caused by a number of things. For instance, maybe there is blockage to the radiator or the radiator itself is blocked with debri not allowing proper air flow. The condition is normal in that the system is trying to disspell the extra heat that is present.
Now that said, if there is not heat build up then I would suspect that the temperature sensor is defective.
Apr 30, 2008 at 8:31 AM
