1991 Honda Accord codes
150,000 MILES • 4 CYL • FWD • AUTOMATIC
SXRSFN29
I have a 91 accord that turns on fine, drives great, but as soon as it comes back to idle it looses all power and dies. I turn it back on and it drives fine again until it comes back to idle and dies again. it gave me two codes but i don;t know if its 6 and 7 or 7 and 8. it gives me a quick flash and then six constant flashes, it stops gives me a quick flash and then seven constant flashes. number 6 is the ect sensor, 7 is the tps sensor, and 8 is the tdc sensor. Please help me out.
Thanks
May 29, 2009 at 6:47 AM
KHLOW2008
  • 41,812 POSTS
Hi sxrsfn29,
It should be Code 6 and 7. The first flash sometimes is slightly weaker thus lights up dimly.
To test the code, reset the ECM and unplug the ECT and try starting engine. Recheck the code.
May 31, 2009 at 5:30 AM
