Transmission problem
1991 Honda Accord 4 cyl Two Wheel Drive Manual
I had a leak at a connection on one of the pipes previously repaired in hydralic circuit. I removed and reinstalled that section of pipe in order to repair; however prior to removal, I had pressure in the system. after reintallation, I have bleed the system, but the clutch pedal is still on the floor, and the pressure is not building up in the system, however I could not see any oil leaks at any of the master or the slave cylinders, or anywhere else in the hydrolic circuit.
Apr 21, 2008 at 12:10 AM
