1991 Honda Accord clutch and slave cylinder
1991 HONDA ACCORD
BRYANWESTFALL
Engine Mechanical problem
1991 Honda Accord 4 cyl Two Wheel Drive Manual
i recently replaced the clutch slave and master cylinder on my honda but i still have no pressure on the pedal after bleeding not sure if i am doing something wrong or this may be an additional problem please help.
Feb 18, 2010 at 8:26 AM
You've replaced the slave and clutch master cyl . You bleed the clutch the same way you bleed the brakes. Proper bleeding and no pressure best check again the clutch master cylinder could be leaking internally
Feb 18, 2010 at 8:33 AM
