1991 Honda Accord Car will not move after trans. warms up
80,000 MILES • 4 CYL • FWD • AUTOMATIC
NEVINC09
My accord will not move at all after the trans. warms up. Have replaced the TCM & the ECU still have the same problem. Have power to all solenoids and resistance is within specs. Has not shown any trouble codes at all. After the trans. warms up and it will not move, if I stop the engine and pull the fuse from the ECU and put it back in, the car will move again for a short time. Have not been able to pinpoint the problem and nobody has been able to help. Have had no problems with the trans. since I purchased the car 40,000 miles ago. Had a trans service done about 5,000 miles ago. Trans did seem to have a harsh shift at times.
Nov 5, 2009 at 12:11 PM
  • 75,988 POSTS
Hi nevinc09 and Ty for the donation
How's the tranny condition and fluid level
This two sensors the throttle position sensor and vehicle speed sensor inputs signals to the computer the throttle and governor pressures from there the computer commands and controls the solenois to upshift/downshift, lock-up/overdrive. Lets get it checked out if it continues get it pressure tested.
Nov 5, 2009 at 12:38 PM
NEVINC09
The trans. fluid level is right where it should be and is clean and does not smell burnt. Thanks for your suggestions, I will check those out. However I am still concerned that I do not get any trouble codes with this problem, is that normal ?? Never had any problems with the trans. before now, other than it would give a harsh shift at times.
Thank you,
Nevin
Nov 6, 2009 at 12:10 AM
