1991 Honda Accord ABS
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
TODD WEBB
My 1991 Accord started making a noise that I thought was a belt or pully, come to find out the noise is comming from under the air filter box, the noise goes away when the ABS light comes on, otherwise the noise is constant. Is there a fuse or wires I can pull to fix the problem for now until I can get it to the shop to fix this the right way. It is the most annoying noise ever. PLEASE HELP? Thanks
Mar 29, 2008 at 6:44 AM
BRUCE HUNT
  • 3,754 POSTS
Check the fuses and you will find that either under the hood or in the vehicle a fuse is dedicated to the ABS. Pull it out.
Mar 30, 2008 at 2:41 PM
