1991 Honda Accord 91 accord timing belt
277,000 MILES • 4 CYL • FWD • MANUAL
TEE85
I have a 91 honda accord ex with 277k miles. I changed the water pump, cam seal,crank seal, both balancer seals, timing belt,balancer timing belt. both tensioners and springs. I followed intructions per internet and my 2 service manuals. After all of this I notice that when I accelerate that I hear a slight spark knock or maybe like a valve rattle (don't hear it at idle) and just maybe a little less power on acceleration. I readjusted my timing (15 btdc with connector shorted) I also checked and rebleed my cooling system to make sure that there wasn't any air. Before I put everything back together after doing the belts, I let the car run with the covers off (the radiator was empty) just to make sure it would fire up and I didn't hear any noises.
Nov 29, 2008 at 1:10 AM
JAMES W.
  • 2,394 POSTS
Sorry, but I'm not sure what your question is. Are you sure you don't have your cam timing a knotch off? Please advise.
Nov 29, 2008 at 12:06 PM
