1991 Honda Accord 2 questions
HONDA-DUDE
Shakes or Wobbles problem
1991 Honda Accord 4 cyl Front Wheel Drive Automatic
my 1st honda, still learning basics
1. where is the trans dipstick. think it's up front on right side, (yellow top) ??
2. my car idles-shakes really bad when cold for most part, but still shakes an has a little buzz when i give it gas
also a little rumble noise when idle n, not muffler
Thank you
Apr 2, 2009 at 10:59 AM
KHLOW2008
  • 41,812 POSTS
Hi honda-dude,
1. Yes, you got it correct for this one.
2. Seems the idling speed is too low for cold start and it could be caused by :
a. Misfiring cylinder or 2. Do you have coolant losses or overheating problems?
b. Clogged air passages for the intake system which reduces the idling speed. Cleaning of the throttle body and Intake Air Control (IAC) valve should help.
Apr 5, 2009 at 5:48 AM
