1991 Honda Accord Sometimes Won't Crank
JR_ODEN
when i turn the ignition key, i can tell that it's trying to crank but it wont. sometimes it will crank, but after trying so many times. why is this ?
Aug 29, 2006 at 12:19 PM
SYNCRAIT
  • 235 POSTS
what model accord? i would reccommend the next time it decides to crank go to the auto parts store and have a battery and load test done on the battery and alternator to start because hey..... its free....but to speculate on other possiblilties it could just be a worn out starter and its not as efficent as it used to be but first make sure its getting the amperage it needs to work right IE. fresh battery + good alternator.... good luck :)
Aug 31, 2006 at 4:33 AM
Suggested Repair
When the car does crank, have the battery and alternator load-tested at an auto parts store. Confirm the starter is getting adequate amperage from a good battery and charging system before replacing a possibly worn starter.
Conversation Summary
The owner of a 1991 Honda Accord says the engine often will not crank when the key is turned, though it sometimes starts after many attempts. The expert asks for the Accord model and recommends a free battery and alternator load test the next time it cranks, noting a worn starter is possible but power supply should be checked first.
