1991 Honda Accord 4 cyl Two Wheel Drive Automatic
My air conditioner switch will not turn on the compressor
every time it is pushed. If you turn it off and than back on again it will come on most times. Additionally, the unit may be running fine and then turn itself (compressor) off which than again will come back on, when the switch is turned off and back on again. At times the unit turns on in a normal way and runs fine?
SPONSORED LINKS
Thursday, May 14th, 2009 AT 11:54 AM
