1991 Honda Accord
1991 HONDA ACCORD
ERVIN PANGANORAN
Shakes or Wobbles problem
1991 Honda Accord 4 cyl Automatic 111000 miles
test drove car it bog i check found there was no water in it then it turn off and didnt start after that.I talk to ower he did even know where the water went so I know car has been over heated.and i puted water and check All other things work lights a/c and window just wont start will it b fit able ? thank you 200.00 car
Jul 1, 2010 at 7:41 AM
KHLOW2008
  • 41,814 POSTS
Hi ervin panganoran,
You are going to spend more than that for repairing. Synptoms indicates the engine has overheated and caused damage to the head gaskets.
Get a compression pressure test down to get the cylinder readings to verify if there are sufficient compression pressure to start engine.
Sep 30, 2020 at 3:43 AM
