1990 Honda Accord Sputters and Misses
Replace the thermostat. Then purge the air from the system. Keep track of the coolant and temp level. Check the system closely for any leaks. Now the leak may not be a dripping type of leak but might just be a steam outlet and thus an air intake problem in to what is supposed to be a closed and pressurized system.
Thanks Bruce. I apreciate the information, It helped them know whats wrong ALOT faster. I will update you and tell you after they replace wires see if thats what it is.
Suggested Repair
Replace the spark plug wires and thermostat, purge air from the cooling system, and monitor coolant level and temperature for leaks. A leak-down test is recommended and is more useful than a compression test alone.
Conversation Summary
The owner of a 1990 Honda Accord LX with an F22A4 engine reported a rough idle, sputtering and jerking on takeoff and around 10 mph, occasional backfire, fluctuating idle speed, overheating at stops and low speed, an oil leak under the distributor, and a clicking noise around 2000-2500 rpm. New plugs, injectors, battery, alternator, fuses, and the oxygen sensor had already been checked; the number 4 plug wire shocked the owner while the engine was running. The expert recommended replacing the plug wires and thermostat, bleeding air from the cooling system, and checking closely for coolant leaks. The owner said a shop would install wires, replace the distributor seal and thermostat, and run compression and coolant tests. The expert also suggested a leak-down test.
