1990 Honda Accord WINDOWS, GAUGES, POWER SEAT BELTS and TU
WAYUCB7
  • 1990 HONDA ACCORD
Electrical problem
1990 Honda Accord 4 cyl Two Wheel Drive Manual
AFTER REPLACING A SEIZED DOOR LATCH ON MY DRIVER SIDE, A LOT OF ELECTRICAL PROBLEMS HAPPENED. THE POWER WINDOWS ON ALL FOUR DOORS WILL NOT WORK, THE TURN SIGNAL DOES NOT WORK, DIGITAL CLOCK DOES NOT WORK, POWER SEAT BELT DOES NOW WORK, AND THE GAUGE CLUSTER DOES NOT WORK. I'VE CHECKED ALL THE FUSES AND THEY'RE ALL IN GOOD CONDITION. WHERE SHOULD I CHECK OR WHAT CAN I DO TO FIX THIS PROBLEM.
Thursday, August 12th, 2010 AT 11:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
These components only have one thing in common and that is that they all run to the same fuse box. If the fuses themselves are tested OK then the wiring to the box or the box itself may be faulty and need replaced.
Friday, August 13th, 2010 AT 1:55 AM
