1990 Honda Accord will start / then quits
170,000 MILES • 4 CYL • FWD • MANUAL
RUSSELL53
I REPLACED FUEL PUMP. THEN I WASNT GETTING ANY SPARK FROM COIL.SO I REPLACED COIL AND GOT CAR RUNNING FOR ABOUT 20 MILES,THEN CAR STOPS AGAIN AND WOULDNT START BACK UP.IT WOULD TURN OVER FAST,BUT NO SPARK FROM COIL.SO I WAITED A DAY,AND WENT BACK TO TRY AGAIN.PUT THE DISTRIBUTOR BACK ON,HOOKED UP WIRING,AND CAR STARTED AND RAN FOR ABOUT 20 MINUTES,THEN JUST CUT OFF BY IT SELF AND WOULDNT START AGAIN. I CHECKED THE MAIN FUEL LINE TO THE INJECTORS AND NO GAS PRESSURE THIS TIME,WHEN I OPEN THE SCREW ON LINE!!! I HAD TO REPLACE BATTERY DUE TO BAD CELL. ANY SUGGESTION,WOULD BE APPRECIATED!!
Mar 2, 2009 at 2:26 AM
F4I_GUY
  • 3,302 POSTS
If you have no fuel pressure. Suspect a faulty main relay.
If you have no spark, suspect a faulty ICM.
Mar 2, 2009 at 9:36 AM
