1990 Honda Accord Water Pump replacement
160,000 MILES • 4 CYL • FWD • AUTOMATIC
WOB
Daughter was driving car and water pump went out completely. Luckily she was a short distance from home and did not overheat the engine. On the way to be repaired the engine totally quit when the timing belt came off. We replaced the pump and the timing belt, but are having difficulty getting it started. Timing belt is properly aligned and there's spark and fuel. Any suggestions on what to look for?
Sep 12, 2008 at 9:03 AM
KHLOW2008
  • 41,812 POSTS
Hi Wob,
Test the compression, it could be bent valves causing compression leaks. Do a wet test too.
Sep 16, 2008 at 7:01 AM
