1990 Honda Accord shift light blinking
MORGONNA
Computer problem
1990 Honda Accord 4 cyl Front Wheel Drive Automatic
ok i had a over heating problem but the car would still start we replaced a hose that was bad and cracked but we had to take the distributor to replace it. we thought it might have been the ECU or TCU so i replaced both . but it still isn't starting. it turns over fine i'm just getting a trouble code from the shift light on the dash but not from the ECU. please tell me if it could be the distributor?
Mar 27, 2009 at 9:26 AM
KHLOW2008
  • 41,812 POSTS
Hi morgonna, The shift light blinking and non starting are usually caused by a faulty PGM-FI main relay.
https://images.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay90Accord_4.jpg
Did you check if the spark plug wires were correctly installed? Are you getting sparks at the plug wires? If you had removed the thermostat housing, recheck the ground wire installation on the housing.
Mar 29, 2009 at 6:32 AM
